3 Wiring a CS130?
3 Wiring a CS130?
Can a CS130 alternator be ran as a 3 wire only utilizing two of the four pins on the alternator terminal?
I have a 140 amp powermaster alternator I just bought. For convenience I decided to get the 1 wire version but I have noticed that sometimes when using remote start (100% of the time if the A/C compressor clutch is engaged), the engine will not rev high enough to trigger the regulator and I will come outside to find my car running off the battery.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Glowsock
01-09-2017 04:06 PM
