vats help info
Car: 1990 camaro iroc
Engine: 350 vortec tpi
Transmission: built 700r4 3500 stall
Axle/Gears: 10 bolt 3.42 posi
vats help info
During my day of searching to find out how to get my car to start I tried the resister nothing was working vats box fried. So I finally I tried an ecm from a not vats vehicle jumped the starter relay and sure enough fired right up. So a simple solution jump the starter relay and plug in a non vats ecu its a temporary fix if Ur broke I wouldn't recommend doing it for long as anyone can steal your car
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
Re: vats help info
Not unless you are able to throw in under the dash a on/off switch*...I nkow of few guys who did this to get by!
Re: vats help info
What's a memcal chip sorry new to electronics
Re: vats help info
So I can swap that from my non vats ecm to my vats ecm and it will run
Re: vats help info
I don't have that maybe cause I have tbi
Re: vats help info
Still ran the same after switching it
Re: vats help info
Ya thats in the ecu I switched the black chip into it from 305 still runs like 350 chip
Re: vats help info
No meant it gets to much gas 350 tune
Re: vats help info
It was fine before ecm swap n yeah mill was blinking fast
Re: vats help info
Top is black no numbers
Re: vats help info
Lol its out of a 93 3500 4x4 all I had what would I need to get to make my car run how it did before an ecm that has to enable fuel via vats is out of the question they messed that up when they tried to steal car
Re: vats help info
Alright thanks I'm gonna get it tuned out 9mpg sucks
3rdgenparts
05-21-2016 11:50 PM
Linson
10-01-2015 09:50 PM
