No fuse housing for f/p oil pressure fuse?
Car: 1985 Firebird
Engine: 2.8l
In the fuse block, block number 2 which in my 85 firebird is supposed to have a Fuel Pump and oil Pressure fuse. just inst there? anyone have info on this? I have the original owners manual and I am looking to make sure I know what fuses go where. And this entire housing is missing as in. The rods that secure the fuse in place are no longer there in stall #2
your thoughts?
your thoughts?
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
The Pressure Is ON !
The F PUMP fuse is supposed to be 10 amps.
Any “fuel pressure fuse” that might be in the circuit will not be in the fuse block.
No need to worry about the latter unless all other circuits are restored but the pump still won’t run.
Happy Racing!
After The Fourth Barrel Roll I Lost Control Of The Car
Happy Racing!
ambainb
04-25-2016 09:21 PM
