Hazards work, turn signals don't
1 Post
Car: 92 Camaro Z
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
My turn signals do not work however if I turn the blinkers on they work fine. I tried replacing the turn signal flasher with a new 552 replacement flasher and still nothing. The switch seems to be in ok shape as it clicks into place without being forced. The fuse is fine also.
What should I check next?
Thanks guys
Thanks guys
Re: Hazards work, turn signals don't
I believe the hazards and turn signals use separate flasher units. You probably changed the flasher for the hazards.
My memory has faded a lot, but IIRC the flasher for the turn signals is mounted by itself to a clip attached to one of the dashboard brackets. The flasher for the hazards is mounted to panel under the dash.
1 Post
Car: 92 Camaro Z
1 Post
Car: 92 Camaro Z
The ignition is on as well
I am not seeing any power at the flasher, even when i turn on the directional. The flasher wire looks like it runs into the ECM so i couldnt track down what was causing the lack of power.
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Do your back up lamps work?
Do you have power on both sides of the fuse? The fuse or contact might be bad even though they passed a visual check. You can also try swapping two fuses of the same rating.
If you have power exiting the fuse but not getting to the flasher, I would probe the dark blue wire at the flasher and the fuse. There must be a break in the wire. No worries, the dark blue wire (or the purple) does not go to the ECM. That is a completely separate system.
http://www.austinthirdgen.org/mkport...ithout_T61.jpg
Let us know what you find.
Lou
Lou
1 Post
Car: 92 Camaro Z
Lou
Lou
I ran 12 volts to the wire that runs into the distributor cap for the ignition. As soona s i did the blinkers started working. Obviously this isnt a solution but i may shed some light on whats causing the issue. i also think i have a VATS malfunction, as the car will not turn over anymore. Whe i turn the key i dont get 12 volts to the purple wire on the starter.
I had the same problem,gages wouldnt work either. I chased wiring diagrams, tore the dash apart, I was at my wits end. My problem was I did a visual check of the fuse. I pulled it and looked at it. Not melted, could clearly see the contact was complete across both blades. New fuse and voila! I coulda kicked myself in the ****.
db057
08-11-2015 10:11 PM
