Power Seat Guru
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Power Seat Guru
Anybody have any experience on Power Seats,this is what I did,I connected the harness to a good battery and the seat switch works the way it's supposed to(2 different switches but the same) but the motors wouldn't run,so I jumped the motors to see if they were the problem but they run when I jump them,so I disconnected the plugs at the motors and I'm getting power to the plugs also,Am I missing something ?????
I followed all the testing directions,
and it seems that I'm getting power at the 6 plug terminal junction in all the positions when power is applied,is this where the test is applied???
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Power Seat Guru
If you are getting power to the connector at the motor, yet the motors run when 12v is applied directly to them, it must be a connector problem. Suspect either corrosion on the terminals not letting enough power through, or a terminal has spread and cannot make proper conact.
Engine: 5.0 EFI
Re: Power Seat Guru
I'm totally baffled why these are not working,they should be working,I did check all the wire ends and plugs and they are not separated or corroded.I'm thinking I have two bad switches,one that it came with and one I bought of Ebay used because i'm getting power at the 6 prong plug at any position and according to the testing procedure that shouldn't happen.
Engine: 5.0 EFI
Re: Power Seat Guru
This is the terminal were I'm getting power in any position,is this where your supposed to do the test????
Engine: 5.0 EFI
Engine: 5.0 EFI
Re: Power Seat Guru
There are 3 of these plugs,1 for each motor,I have power to each of them and when I plug them into the motors,I get nothing.
Car: 1986 IROC-Z
Engine: 305 T.P.I.
Re: Power Seat Guru
Still sounds like a ground problem to me. If you have voltage at the conn for the motors then they should work. However the switch itself might work the ground too I'm not sure without a diagram
Car: 1986 IROC-Z
Engine: 305 T.P.I.
Re: Power Seat Guru
Plug the seat switch up. Put a test light on the forward seat motor connector and test for the light to come on when moving the switch to "forward" (just as if you were trying to slide the seat forward) Then swap terminals and move the switch to the "backwards" position. Does the test light light up?
Engine: 5.0 EFI
Re: Power Seat Guru
If you look at the pic of the blue plug above,if I put the test light in one side and move the switch forward the light,lights but it doesn't light on the other side of the plug until I move the switch in the opposite direction.
Car: 1986 IROC-Z
Engine: 305 T.P.I.
Re: Power Seat Guru
Yep that's exactly what should happen. The switch is just reversing the polarity. Sounds like you have a ground problem, which will be the black wire on the bottom right hand side of that diagram you posted. Check that
Engine: 5.0 EFI
Re: Power Seat Guru
I plugged up the motor and now both sides of the plug light up in any position,I don't think that's supposed to happen.when the plug is not in only one side at a time work on the plug.
Engine: 5.0 EFI
Re: Power Seat Guru
Engine: 5.0 EFI
Re: Power Seat Guru
each side of that plug lights up in forward and reverse.
Engine: 5.0 EFI
Re: Power Seat Guru
1bad86,thanks for the help,I'm calling it for the night,thanks a lot.
Engine: 5.0 EFI
Re: Power Seat Guru
Found the problem,'I pick up another seat base and it worked good,so I switched the wire harness over and everything worked good, it's that big rubber switch receiver.So now I have a spare,
1992 Trans Am
05-10-2023 08:19 PM
sailtexas186548
08-24-2015 11:11 PM
