Tachometer Wire
Car: 74 Nova prostreet 87 Iroc Z28
Engine: 427 671 blower 350 Built
Transmission: 700R4 both
Axle/Gears: Dana 60 an a 323 posi.
Tachometer Wire
Could someone tell me how to hook up my stock tach. to my msd box an what color wire is it? Iam running a 6al box in a 87 iroc the msd directions are not to clear. Iam using a blaster 2 coil an I dont remember if there were 2 wires to the stock coil or not (pink or white) do I still need to hook up the magnitic pick up from the dist. also.Dist. has no points. Thanks.
Re: Tachometer Wire
Do i take the white wire from the plug, cut it and hook it to the msd box tach? thank you.
Re: Tachometer Wire
here is a real clear picture how to wire it you can see the wires spliced together
The harness will need to be cut and hooked on to use solder and shrink timing for trouble free issues.
http://www.ebay.com/itm/MSD-8876-Wir...389cb3&vxp=mtr
Re: Tachometer Wire
ambainb
04-25-2016 09:21 PM
