Trunk mounted battery, 2awg ?
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, LT1
Transmission: TKX, 4L60E
Axle/Gears: 3.42, 3.23
Is 2 gauge enough for a trunk mounted battery?
-- Joe
-- Joe
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Trunk mounted battery, 2awg ?
Personally I think a little on the small size in regards to batt current and voltage drop over the distance ( assuming you are using it for the starter)
AWG 2 is only 6.5 mm ( 1/4" ) dia wire
http://www.engineeringtoolbox.com/aw...uge-d_731.html
Nice voltage drop calculator at bottom of this page ( select 12 VDC )
http://www.powerstream.com/Wire_Size.htm
You can input cable size and run length to so what actual voltage will be
I used 00 welding cable on mine
Car: 87 Iroc 5.7 /86 Trans am
Engine: 5.7 TPI / 350 carb
there are a lot of trunk mounted battery cars ( mostly european ) I haven't seen any using 00 wire. It wont hurt anything but def makes the project more expensive. If you have a high quality 1 or 2 gauge that should be fine, just make sure the ground is good. or you can always default is bigger is better!
IROCZDAVE (88-L98)
09-02-2015 08:49 AM
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
