92 RS Camaro Speedometer
Car: 1992 RS Camaro
Engine: 383
I've a 92 camaro that was converted from stick to automatic transmission. The speedometer does not work. I recently removed the automatic transmission for overhaul. There is an electric wire from the left side of the transmission. I don't know whether a stick transmission's speedometer will work with a automatic transmission? All inputs are welcome.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Speed Reading
Whoever converted it forgot to hook up the sensor.
The wire you see needs to go to the Vehicle Speed Sensor or VSS.
If you new trans has a 2000 Pulses Per Mile or PPM, the speedo should work correctly.
Happy Racing!
He Must Have Been Be Cheating - Because I Was And He Almost Beat Me.
Happy Racing!
ambainb
04-25-2016 09:21 PM
