injector relay/fuse..
Car: 89 Z28 T-Top
Axle/Gears: 3.27 posi
where can i find find the fuse or relay..
problem is that i am not getting any power to my injector connectors but i do have spark on plugs and do get fuel pressure but car wont start.. any help would be appreciated even if its not a fuse or relay i should be looking for..
thanks
thanks
Car: 89 Z28 T-Top
Re: injector relay/fuse..
yes but all those are good.. i just finished tracing the plug for the injector and goes straight to computer. and there i saw the other plug for injector which is two green wires missing a plug... this car has alot of mickey mouse.. so now im wondering if its a plug or a fuse that it takes there.
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
The injector power comes from fuses INJ#1 and INJ#2. If the fuses provide power, check connector C207, next to the ECM. Pins B and G have pink/black wires that provide the power from the fuses directly to the injectors.
If you have power at the fuses but not at the injectors, you either have a problem at the C207 or a break in the wiring somewhere.
thejimsterz28
09-15-2015 05:37 PM
