I need some serious help. Completely confused.
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
Okay, let me start off by saying, I may have screwed up here. On that note, if you're gonna flame me for it fine, but at least answer my questions in the process. I have also been up one side and down the other of the search button, and all over austinthirdgen for their wiring diagrams. I'm still screwed. I swapped my motor to a brand new 357ci carb'd and vacuum advanced motor. I removed the whole computer and harness before swapping in my current motor. I am in fact an idiot. While I dont need the computer side of the harness, I do in fact need the c100 side, which is still there but no longer hooked up. These are the wires I have, that have no home.
Going toward headlights, driver side frame rail, used to be wrapped in the same wire loom as main c100:
Grey/orange stripe-
Pink/Black stripe-
Green/Yellow stripe-
Black/White stripe-
Coming out of C100:
2x Black/White stripe-
Pink/Black Stripe-
A Tan or brown wire-
Blue-
Thick Purple-
Thick Black/Red stripe-
thin purple-
Dark Green-
Light Green-
Yellow-
Fuel Pump Relay:
Black/White stripe-
Red-
Pictures are in order of page, top wires being fist picture and so on.
*(Thick Purple wire, and Thick Black/Red stripe wire not in pictures)*
Grey/orange stripe-
Pink/Black stripe-
Black/White stripe-
Coming out of C100:
Pink/Black Stripe-
Blue-
Thick Purple-
thin purple-
Dark Green-
Light Green-
Yellow-
Fuel Pump Relay:
Black/White stripe-
Red-
Car: 1992 RS 6spd
Re: I need some serious help. Completely confused.
As a complete side note, I am wiring up my own gauges through the stock wiring, the gauge side is already done and has been tested, but I need to know which of those wires go to the oil pressure sender, and to the temperature sender I put in seperately. The wires coming out of c100 that is. Thank all of you for your continued patience and help.
Look here if you haven't already: https://www.thirdgen.org/forums/elec...ic-wealth.html
Car: 1992 RS 6spd
I'm going to comb through every page of that.
Car: 1992 RS 6spd
I'm still looking through those pages, and I'm having a bit of trouble deciphering all of it..
Car: 1992 RS 6spd
If someone can fill in all of the blanks in my original post, and have it be right, I'll pay a reward of 10 bucks through paypal. Thanks.
Car: 1984 Berlinetta Camaro
Engine: '97 LT1
Car: 1992 RS 6spd
1992 Chevrolet Camaro 5 liter TBI 5spd. Thats what the original car was from the factory.
Engine: '97 LT1
Grey/orange stripe- Park/Neutral, which should be your clutch anticipate switch on manual, I believe.
Pink/Black stripe- ECM Fuse 12v IGN or INJ FUSE
Green/Yellow stripe- Not sure.
Black/White stripe- ALDL B
Coming out of C100:
2x Black/White stripe- GRND (C7), or SRS (F8).
Pink/Black Stripe- Emissions Common
A Tan or brown wire- If it's more brown, it's fan relay (G8), if it's more tan, it's the oil pressure gauge (E5)
Blue- Back up lights
Thick Purple- Starter interlock
Thick Black/Red stripe- Power Distribution IGN sw
Thin purple- VSS
Dark Green- coolant temp gauge
Light Green- Back up lights
Yellow- VSS
Fuel Pump Relay:
Black/White stripe- Ground
Red- Power
These are, to the best of my knowledge, correct.
Coming out of C100:
Thin purple- VSS
Yellow- VSS
Fuel Pump Relay:
Red- Power
Car: 1992 RS 6spd
Thank you.
