egr wire?
Old 03-20-2012 | 08:09 AM
Facekill88's Avatar
Car: B4C
Transmission: Man 5
egr wire?
I dont know what it hooked up to. can someone help.
Old 03-20-2012 | 08:58 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: egr wire?
EGR solenoid wire or EGR temp sensor wire???????
How do you know it is a EGR wire?
Old 03-20-2012 | 09:04 AM
Facekill88's Avatar
Car: B4C
Transmission: Man 5
Re: egr wire?
I know its a wire with a plug at the end of it. Its comeing off the back of the egr. Yes the egr sittins on top of the block, right. Vac line is in, I just don't know where the pulg this thing in to.
Old 03-20-2012 | 01:12 PM
Facekill88's Avatar
Car: B4C
Transmission: Man 5
Re: egr wire?
Anyone know. egr with a wire on the back of it, what does it go to?
Old 03-20-2012 | 05:59 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: egr wire?
Its comeing off the back of the egr. .
You are making little sense.
1st you say you have a wire with plug on it that you don't know where it goes
then you say it goes on the EGR valve??????
Old 03-20-2012 | 07:02 PM
Facekill88's Avatar
Car: B4C
Transmission: Man 5
Re: egr wire?
Sorry its from the back of the egr. It has a black pulg on the end of it, I unhooked it when I upgrade the injs. Its throwwing a code 12 on the ecu.
Sorry about the earlier post.
Old 03-20-2012 | 10:28 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: egr wire?
Sounds like the EGR temp switch , you should have a plug to match coming out of the engine harness near there
Than is not a code ; just the ECM saying it is connected and there are no codes present
Spyder_TheGamer
12-25-2015 06:07 PM
db057
09-04-2015 08:57 AM
Out-Cast
09-03-2015 10:05 PM
Bubbajones_ya
08-28-2015 03:17 AM
Quick Reply: egr wire?
