Bypassed VATS/Car Wont Start
Car: 89 firebird rs
Engine: 2.8
I Bypassed vats with resistors got all that done....
Bought a new starter relay thinking it was that
Car doesn't do anything when i hit the ignition
What should i check next? neutral safety switch
p.s. When i manually add power to the starter from the battery the car cranks but doesnt fire up...
Car: 1987 Iroc Z28 Camaro
Engine: 5.7 TPI
Re: Bypassed VATS/Car Wont Start
be sure the block is properly grounded. One cable from the neg batt to the chassis, one from the chassis to block, one from the block to the firewall. Sounds exactly like what I had one do to me.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
You didn't bypass VATS ; all you have done is make it "think" the correct key is in the Ign
Everything in the starter circuit from the wire out of the Ign switch to the starter solenoid ;
but read below 1st
(with key on ????? )
That would indicate a problem with the VATS module; it is not sending the fuel enable signal to the computer
( or operating the starter relay)
but read below 1st
