vss question
1 Post
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
vss question
Can I still get a reading from my vss without the ecm, if not then what other options do I have besides running a cable operated speedo?
1 Post
Car: 87 GTA t-top
Re: vss question
87 TPI auto, just want to eliminate the stock ecm, but want to still have speedometer working.
Whats needed or it will just work like that, from vss to buffer box to speedometer?
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Re: vss question
The buffer box on my 91 V6 Bird is on the passenger side directly behind the dash where the map pocket goes. It was between the plastic dash and the matal backing. It is almost beside the ECM.
Car: 1984 T/A
Engine: LQ4
Re: vss question
I think i have a similar question. im putting the rear end from an 87 bird with higher gears on my 92 bird. is there any way to prevent the speedo from being off? the donor car will be available.
Re: vss question
you can see on the attached link the gear ratio and tire size calculator.
http://www.transmissioncenter.net/sp...n_______va.htm
Re: vss question
you can always recalibrate the speedometer with a dakota digital sgi-5
http://www.summitracing.com/parts/DAK-SGI-5/
Car: 1984 T/A
Engine: LQ4
Re: vss question
Car: klowny1969 <-youtube 4 3rd gen vids
Engine: subscribe to klowny1969 on youtube!
Transmission: subscribe to my channel on youtube
Re: vss question
Here is a video of how to calibrate ur speedo using a dakota digi box..
