Tail light issues...wiring?
Old 02-16-2012 | 10:19 PM
jonhues3's Avatar
Car: 1992 Firebird
I've got a problem I've not found on the boards, hopefully not overlooked. I've got 82 T/A tail lights on my 92 bird, which shouldn't make a difference, but you never know, and my brake lights work (the middle two lights) but the outside two (backing and outermost tails) will not. I've checked the bulb and fuses, the problem doesn't seem to be there, but nevertheless the lights won't work. The wiring in the back looks stock but idk, especially with some of the things I've found in this car. I discovered the problem when I got some backing bulbs to replace what I thought weren't working(I was wondering why it was so hard to see backing at night) and to my horror I discovered this problem. Anyone run into this before? Know why it might be this way? Thanks
Old 02-18-2012 | 11:25 PM
jonhues3's Avatar
Car: 1992 Firebird
Re: Tail light issues...wiring?
[edit] the wiring is definitely not stock. I was completely wrong.
Old 02-20-2012 | 03:55 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
PO Power Problem
Because the PO apparently modified the wiring you can probe to remode.
Use a 12 volt fused source to probe which wire illuminates which bulb.
Just connect ground to ground
(black wires in most cases) then using the + wire from the supply, touch the unknown wires.
When the bulb illuminates, attach a label to the wire.
You can find out what wires are powered and when by using a voltmeter or test bulb.
Then splice the corresponding wires to the tail lamp assembly.
Happy Racing!
After The Fourth Barrel Roll I Lost Control Of The Car
Old 02-21-2012 | 07:07 PM
camaro24's Avatar
Car: 1985 Chevrolet Camaro
Engine: V-6/V-8
Transmission: Automatic
Axle/Gears: Regular Axle and Gears
i have a 85 camaro & my reverse lights & signals will not work in the front or rear. i replaced fuses already and checked lights everything is good any suggestions ?
Old 02-28-2012 | 04:18 PM
NINÅ's Avatar
Transmission: 765R4
Enlightening
TURN SIGNALS:
Turn the ignition key to the RUN position.
Using a test light
(the type for testing for voltage, not a continuity tester) probe the purple wire going to the steering column connector.
It’s the larger of the connectors located on the right side of the steering column.
If there’s power there, turn the blinker to the left position, then probe the
LIGHT blue wire at the same connector.
Is there power there?
With the key in the RUN position probe the dark blue wire at the switch on the right side of the shifter.
Happy Racing!
My Brakes Don’t Work AT ALL When The Car Is In The Air
skeltor
02-02-2016 10:37 AM
florida_gators
Exterior Parts Wanted
09-07-2015 07:19 PM
flash2042
Interior Parts Wanted
09-07-2015 07:15 PM
Ian Irvine
09-04-2015 08:08 AM
luvofjah
09-03-2015 07:08 PM
Quick Reply: Tail light issues...wiring?
