vats issue??
#51
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: vats issue??
the vats bypass box is simple to wire. its just a switched 12v, a ground, and an output to the ecm. the downside is theyre like $50. you can sweet talk someone local into disabling the VATS system in your computer for cheap, or get a prom with it already done, but that requires cracking open the computer.
normally the contacts in the cylinder wear and dont make good contact. id measure the resistance in both the run and start position on the column before ruling it out entirely.
#52
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
Re: vats issue??
Also, if the resistor trick fails, I'm just going to do a new ECM. Gain a whole lot of stuff from that beyond just disabling the VATS and its more within my skill set to do.
#54
Car: 2003 F-150
Transmission: 4R70W
Re: vats issue??
Well, for now the resistor is working for me. I'm not getting the lock cylinder replaced, so I just need to remember to unplug the resistor.
