1989 cluster to 91-91, 140 Cluster
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Just wondering if I will have any issues changing out my 1989, 120mph cluster out to a 91-92 140mph cluster or is it just a simple swap??? Thanks
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: 1989 cluster to 91-91, 140 Cluster
Only thing you need to do is to take out the odometer from the speedo and put it in the newer cluster to keep legal. I swapped a 90-92 (forgot what year exactly) 120 cluster into my 87... Just make sure you mark the position of the speedo needle on the outer edge of the gauge face before you remove it so your speedo stays as accurate as possible.
