Question about a kill switch
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
I have a manual harness in my car. I just want to know if I can add a switch to where the button you press with the clutch pedal is. The purple and yellow wires you use to start the car. I was looking to add a switch to there as a kill switch and was wondering if its safe to do so or if anyone has done it before. Also anything I sould look out for if I use it
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Question about a kill switch
it wouldnt be a kill switch, more like a "have to press while starting" button. adding a secondary button in parallel on the clutch safety switch shouldnt cause any issues.
Car: 89 IROC
I just want to add it there as it makes it so much easier to run and the fact is I dont have the clutch switch so this would add some safty to starting it too. Looking for a switch is dam impossible as everyone from my local parts store isnt the right one
Car: 91 Camaro RS
so your car doesnt have the clutch safety switch? rock auto has them. $5. its under electrical - relays $ switches, clutch pedal position switch. it doesnt come with the pigtail, so youll need to get one of those too if yours is missing.
Car: 89 IROC
I looked up the part and its the same one I have here but it doesnt plug into my harness for some reason. Either i got it backwards or im a idiot but it just doesnt go
Car: 89 IROC
I have 4th gen pedals and a thrid gen switch that goes with my 87 harness for the car. Car is a 89 but all the dash wiring was redone for a 4th gen dash swap so I took it all out of the car and took a 87 unmolested harness from a parts car I had
Car: 89 IROC
I got it new and the harness pig tail doesnt fit the switch at all. I will take alook again at it but the dash connector is twice the size of the switch where it goes into.This is it here
Car: 91 Camaro RS
id look into getting a switch with pigtail and splice that in place of the pigtail thats there. does the switch physically fit on the pedal mount?
Car: 89 IROC
Im just gonna put a toggle switch in for now and look into replacing the stock switch eventually. The switch I have does fit on the peddles bit not the wiring. I think there was a stock connector between the 2 pieces from what I can remember. Its been along time since I took out the harness
Car: 89 IROC
if anyone knows please let me know. For now im gonna cut the stock one off and put it to a pincess auto switch under my seat so it acts as a kill switch. Another place I might try is the ashtray too as its covered up
Car: 91 Camaro RS
unless the thing still plugged in in the pic was just cut out. hard to tell from the pic
Car: 89 IROC
It might have been home made as thats what it looked like to me. Ill look into maybe extending it with spade connectors to the switch
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Iroc8t8
08-26-2015 08:14 AM
