got a new camaro, no key for the VATS
i just got a new camaro and there is no key because the guy that owned it before me got caught for being and illegal immigrant and took his key to mexico lol so how do i disable the VATS system? i dont even know if it runs but it looks great and its white and for $200 i had to buy it
1 Post
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
Re: got a new camaro, no key for the VATS
what engine if its a 305 tbi i used a caprice computer and it bypassed the vats
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You can do the normal VATS resistor thing, and test each of the 15 possibilities until you get the right one - the resistors are about $1 at Radio Shack, and your time.
Or, you can get a VATS bypass module fromebay, Painless, etc. for about $50, and wire it in per instructions.
www.thirdgen.org/vats https://www.thirdgen.org/vats_passkey_system
soo, i just went and got the computer from a craprice 305 TBI car and it didnt work, the caprice didnt have VATS so idk whats wrong, i did this route cause idk what the resistance of my key is and i dont want to go through all the 15 options with the resistors, but when i hooked the computer up, the security light still came on, but no crank, its like VATS is still stopping it but that cant be can it? cause i changed the computer, this is making me go crazy, i need all the help i can get
and the number on each are:
the original: SERV. NO. 1228746 ANTT
86ANTT K192580878
16127501 ANTT
the numbers under the bar code are: 86ANTTK192580878
the Caprice computer: SERV. NO. 1228746 APFN
86APFN K192432073
16130381 APFN
the numbers under the bar code are:86APFNK192432073
86ANTT K192580878
16127501 ANTT
86APFN K192432073
16130381 APFN
ok so i changed the PROMs around in the computers and still nothing, the first time i turned the ignition on, the security light didnt come on, but then i turned it off and back on and then the security light came on
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
The VATS module is independent of the ECM, so there is no way the Caprice would have worked in your car. He was giving you bad advice. I bet his VATS was already resistor bypassed & he doesn't even know it. And that is why it would have worked on his cars.
All you can do now is start assembling the 15 different resistor values one by one (hopefully yours will be one of the very first values) for the cheap bypass mod, or buy the more expensive bypass module mentioned above. If you had the key, you could measure it & duplicate the value using resistors.
Do the resistor bypass method. You won't regret it.
Car: GTA
RC, it is 2 min between each try before the Module resets & can be tried again. Don't wait long enough & it won't have reset itself & you'll still be in the "not correct" cycle & the 2nd one you try can't work, even though it might have been correct.
http://www.austinthirdgen.org/index.php?pid=10
Car: GTA
Oh....The chart in the link I gave you shows direct resistors that will work by using only 1 resistor. You can always just buy an assortment at Radio Shack & daisy chain them to get the value you need.
