Are Thirdgens Supposed to Draw a Small Amount of Power, Even When Turned Off??
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: WC T-5
I'm trying to track down a power drain on my battery.
When I have everything that could be drawing power disconnected or turned off, (hood light & after market audio amp disconnected, doors & hatch closed ect.) I connect my tester light between the negative terimal, and the negative cable, and the tester light illuminates:
![](http://farm4.static.flickr.com/3174/5766034422_ae95aba541_z.jpg)
After pulling all my fuses and disconnecting the starter and alternator, the test light stayed on, so I figured maybe Thirdgens are supposed to draw a minute amount of power even when shut off (some modern cars do). So I tried hooking up a spare license plate light, figuring it would require more power. When I hooked it up I it stayed unlit:
![](http://farm4.static.flickr.com/3398/5769372170_42118b0f55_z.jpg)
But I know I have the light hooked up properly because when I open the door it illuminates:
![](http://farm6.static.flickr.com/5190/5768832379_203484b24e_z.jpg)
So what's this telling me? The draw on my battery, whatever it is, is just very small? Why would one light illuminate, but not the other?
What's also bizzare, is that when I first hook up the license plate test light, it will illuminate for a second, and then go out.
![huh](https://www.thirdgen.org/forums/images/smilies/huh.gif)
Car: 1986 IROC-Z
Axle/Gears: Dont know yet
Re: Are Thirdgens Supposed to Draw a Small Amount of Power, Even When Turned Off??
I have an 86 IROC and with everything off the only parasitic drain, that is Radio memory and ECM Memory, im only pulling .18 Amps which I believe is normal for Memory on ECM and Radio.
1 Post
Car: 91 Camaro RS
Engine: 305 TBI
Ok, so that might explain why the tester illuminates, but not the license plate bulb.
The tester is 3.5V. Would .18A be enough to illuminate it?
The license plate bulb I used is 14V .3A and 3.78 watts. So I'm guessing a small draw like .18A wouldn't be enough to illuminate it. Forgive my ignorance I don't know much about electronics.
Maybe I don't have a parasitic drain after all...
![Embarrassment](https://www.thirdgen.org/forums/images/smilies/redface.gif)
Car: 1986 IROC-Z
I believe that at 3.5 volts would be enough to illuminate as its very low voltage, but a regular 12 or 14 volt bulb would not. I used my meter on the Amp side to test this as I wanted to know what I was drawing after I found my drain. It turned out I accidently left the hatch light on without knowing it. lol.
Car: 1986 IROC-Z
Yes, A DMM is the best way to go when tracking down a draw or troubleshooting anything electrical in the car. If u dont have one id go and invest in one. Theyre not expensive at all unless u get a really good brand like a fluke.
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Correct me if I'm wrong, but the way you are doing it won't tell you anything. If you are attaching the test light clip to the neg post on the battery and then touching the neg cable, the battery is not grounded so the light will always light up (showing that it's a bad ground.) You have power at the positive post and nothing grounded....when a test light lights up on a ground connection it means you have a bad ground (which is obviously because the neg cable is disconnected). For an ACTUAL draw, get a multimeter and try it.
as long as the neg cable is grounded like it is stock to the passenger fender, then the test light (best to replce with a DMM) between the neg cable and neg terminal will indicate if you car is drawing power. it should NOT draw any type of measurable power with everything shut down, other than the tiny tiny amount the pmc, radio, and alarm use to keep their memories. if you have a draw thats draining your battery, set up your light or DMM and start pulling fuses until it goes out, when it goes out you'll know which circuit is has a short and is drawing power. Then you get to go through that whole circuit to find the short. I'm having a similar problem, its a PITA
Get a DMM, and find the actual current draw.
I'd much rather read the DMM and pull fuses, than disconnect the radio, alarm, and pcm before pulling fuses. I guess if the current draw drops when a fuse thats not on a standby draw circuit that would indicate thats the short, but if the short is in a standby draw circuit you'd need to know the stock current draw to diagnose it.
Yes, stock acceptable current draw is < .01 amps.
I was saying that a DMM is the only way to do it, that a test light will always just be on, even when acceptable standby current draw is being pulled.
novaderrik
08-10-2015 12:44 PM
