MSD wiring
Car: 88' Z
Engine: 350 .60 over
Transmission: W/C T5
MSD wiring
im currently installing my msd ignition and i got my coil hooked up as well as the box hooked up to a 12v source. my question is, i have to wires left a white which idk what goes to and a red which has to be spliced to the ignition switch, im wondering if i can splice that in with the pink wire on the positive side of my old ignition coil, was TBI now carb.
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: MSD wiring
Did you try their website ? They don't hide their install diagrams.
MSD does make more than just one model 'coil and a box', btw.
Car: 88' Z
Re: MSD wiring
i know where wires need to go, i just dont know what wires to use that are located on my car if that makes sense. its a 6al box with a blaster 2 coil and a pro billet distributor
Car: 85 iroc-z28
Engine: 049 headed bbc 4?? C.I.D
Axle/Gears: 3:73 posi
Re: MSD wiring
yea just use the pink wire that went to your old coil i have the exact same setup thats what i did and it works. the whhite wire you"ll just tape up cuz its only needed if your hooking up the box to points style setup hope that helps
Car: 88' Z
Re: MSD wiring
yeah thanks, i had a feeling i didnt need the white one, ive also got a sunpro tach hooked up to the box and works fine didnt know if that would help anyone else
tartagliaz28
08-15-2015 10:59 AM
