92 Camaro RS- Fog light switch gets HOT
Car: 92 Camaro RS
Axle/Gears: stock
Hello to all & best wishes to all. Here is I think my problem. I have installed
the fog lights on my car, I used all GM parts. The dash was already wired
by GM,all I had to do was put a relay and add the fuse. The problem I
think is the fog light switch gets really HOT. Not to the point of melting,
but it gets really warm, is this a problem or normal. Thanks to all.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 92 Camaro RS- Fog light switch gets HOT
Your using the switch to activate the relay, which transfers power directly from battery to foglights right? Like this:
85 = 12v+ from foglight switch
86 = ground
87a = nothing
87 = 12v+ out to foglights
30 = 12v+ from battery
86 = ground
87a = nothing
Car: 92 Camaro RS
Axle/Gears: stock
Thank you Camaronewbie for your reply. I see what you are saying, but is this a hazard or a normal thing for the switch to get that warm?
Car: 1992 RS
Engine: Carbed 350
If you have it wired correctly, then might just be normal. There's a little light in the foglight switch that can get warm simply because lights get warm. But I was using the relay diag to make sure you had an idea as to how it should be wired. If all that the switch is getting is enough 12v+ from the fuse block to activate the relay and light up the little light inside the switch, then it should be fine.
I used factory switch and wiring to put the fogs on my 1992 RS - but not sure I ever felt the switch to see if it was hot, I usually just leave them on all the time. But I'll check mine this weekend and see if it gets hot, and get back with ya.
Car: 92 Camaro RS
Axle/Gears: stock
Again thank you, and that was some fast service. Look forward to talking to you soon. Ty1on2
Car: 92 RS
Engine: 305TBI
how did you find the wires for the fog lights out in the engine bay my car is the same way its all wired inside the car with the switch and relay already there
Car: 92 Camaro RS
Axle/Gears: stock
I bought the under the hood harness off of ebey, it comes with instructions.
With the harness I bought it plugs into the bulk head on the fire wall.
It's just like the factory wiring. The fog lights go off when you put on the
high beams. If I can find the vendor I bought it from I will post.
Car: '92 Firebird + '06 Charger R/T
Engine: Firebird 3.1L V6
Transmission: Firebird Automatic
I got a 92 Firebird that didn't come with fogs, but I want to put them in.
I already have the factory switch, and I see that the connector is already there.
I know which wires have to go to a relay, but I'm not sure where they go from the switch.
Can anybody shed some light on this?
thank ya
thank ya
Just an FYI: Early switches weren't illuminated.
Some info from Jim85IROC that I thought was interesting:
From 86-on, your fog lights would work with your parking lights on and when your low beams are on. As you learned, they won't work with high beams.
BUT... in 85, in addition to many other one-year-only peculiarities, the fog lights would come on ONLY with the low beams. With just your parking lamps on, the fog lights will not come on.
JamesC
JamesC
Car: '85 Z28
Axle/Gears: 3.23 posi
thank ya
thank ya
Hope that helps
Car: 1992 Z28
Engine: 350TPI
Transmission: 700R4 Auto
Axle/Gears: G92
I have a 92 Z28 that came with factory foglights and also gets hot after a while. I am pretty sure its the bulb inside.
