Battery size/style? 88 V6 Camaro
Car: None atm :(
Engine: :(
Transmission: :(
Axle/Gears: :(
Quick question .. what size battery does the car hold and is it side or top post? I'm going to look at one tonight so I don't have a batt to compare.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Battery size/style? 88 V6 Camaro
Look at your cables - do they have side-post ends or top post ends? Most 3rd gens should have side post, but if a previous owner changed it ...
When looking at front of battery, pos should be left side, neg right side - "front" of a battery is the side with the brand label on it. You'd want minimum of 550 cold cranking amps - think mine is 800 CCA.
Otherwise standard car battery, same physical size as 99% of them.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Battery Of Questions
Originally Posted by s4l
side or top post?
Don’t know the original size, but Group Size 75 fits.
Happy Racing!
If Your Communications Antenna Is Not Shaking At Idle, Your Cam Is Too Mild
Car: None atm :(
Engine: :(
Transmission: :(
Axle/Gears: :(
That's good to know. Thank you.
What did your yellow top cost ya?
Denricci22
09-18-2015 09:02 AM
