92 RS changing window defogger switch ??
Does anyone know how to replace the rear window defogger switch on a 92 RS? I bought a new one, because my turns off after about 30 seconds. I must turn that on 50 times just going to work. All wires are intact on the rear hatch, it actually works very well, just stays on for 30 seconds each time.
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: 92 RS changing window defogger switch ??
It might not be the switch itself, mine does the same thing even after replacement. There is a breaker in the fuse block labeled "ACC POWER" that might be opening prematurely and causing the defogger to shut off. It's one of the two squarish silver cans in the block, the other is for the power windows IIRC.
No problem, that's a 35 amp breaker BTW. Let me know how it works since I haven't replaced mine yet, just been living with the inconvenience.
Off-topic - Does that screen name signify you're associated with Boeing Everett, or Corporate in Chicago, or something else?
1992 Trans Am
05-10-2023 07:19 PM
