Turn signals flash real slow.
Car: 85 Trans AM
Engine: Chevy 355
My turn signals flash really slow on my TA but the hazards flash at the normal rate.
Is this a problem with the flasher?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Turn signals flash real slow.
Hazard has separate flasher unit
http://www.austinthirdgen.org/mkport...ody_wiring.gif
Car: 1988 Camaro IROC-Z
Interesting - the passenger side turn signal on my '88 IROC is slow, but the driver's side is fine.
Any ideas?
Any ideas?
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Go to your local auto parts store and pick up an EBL32 ELECTRONIC flasher. and your problems will be solved for good
Car: 91 Camaro RS
Engine: LH6 5.3
Axle/Gears: 3.43 LSD
I have the same problem with the slow flashing and sometimes they just turn on. Also, I have had an issue with my volts. Every time I turn on the turn signals my volts drop bad. I was told that this is called volt drop. I changed my alternator, and the ground wire and replaced the starter. The only thing I can think of is the wire from the battery/alternator to the starter. For my car the battery/alternator wire goes to a fuse box type thing and then splits into two wires both heading to the starter.
Prodigious
11-07-2020 09:23 AM
Fronzizzle
03-18-2019 08:29 PM
