Another guess this plug/wire.
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Was under my car a minute ago and found this hanging behind the alternator.My guess is its either emissions or a/c but i dont see anywhere it goes.
Well pics aren't loading and I cant figure out why.the plug is black and looks like an injector plug.As best I can tell it has a red and a white wire going to it.Its kinda hard to tell cause the wires are so dirty.Cleaned them up the best i could.
OK I got one to load.what do yall think?
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Re: Another guess this plug/wire.
Anybody?It comes out of the loom that goes to the alternator.
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
it looks like an injector wire.
look at the 5th picture in this link. https://www.thirdgen.org/forums/ltx-...erchanges.html
Car: 87 IROC Z
Engine: 5.7 L98 TPI
I agree.But I have no idea why.All my injector plugs are spoken for.Guess I`ll have to trace it back through the loom.
sorry I didn't see that you already mentioned it in part of your post
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Yup,thats it.Forgot about that one somehow,the metal clip came off.No telling how long its been off.Would this cause a hard starting issue?It fires right up when cold but takes a few seconds if its been driven then cut off and try to restart.
ITs a pita to plug that sucker back in.I prolly could have loosened the alternator to make it easier,but I guess im hard headed.It will prolly come back off till I get another one of those metal clips.We will see.Thanks fellas!
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
It should only cause hard or extended starting while the engine is cold (if not hooked up). If the engine is warm past 'x' temperature, the 9th injector is just there. Even with the engine cold, the 9th injector only works briefly.
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Thats what I thought,but it fires right up when cold.even with it disconnected.kinda weird.AFAIK THE 9TH INJECTOR WASNT TUNED OUT OF MY PROM,and its all still there.
