Mystery wires - code 33
Car: 1987 Red IROC-Z Hardtop
Engine: Bolt on 305TPI
Axle/Gears: 3:23
Good afternoon!
Ive been having trouble with a code 33 problem, limp mode sucks when your an hour away from your house.
I found this blue wire and it looks to go to the ECM? Dont know if it has any real purpose but i want to be sure.
I figure my issue is wiring because ive searched all up and down these threads from people saying relays to replacing ECMs and trouble shot the sh*t out of my car for the past 2 weeks so right now im looking for loose grounds/wires that might cause a problem and only found a couple.
Also what are the grounds behind the motor for?
Re: Mystery wires - code 33
I have the same wire, it was taped away but it is a ground. I don't remember taping it away myself, I think it's a factory taping job.
Here's mine, the blue one is still taped away in this pic. The black is another ground (for the hood light) BTW, I have an 87 TPI too (350)
![](http://www.vettemod.com/forum/imagehosting/24c6a2d36ce9a2.jpg)
The grounds on the cyl heads are the main system grounds for the ECM & electrical system. There's also a ground strap to the firewall.
My car wouldn't fire the injectors when cranking, there was no cranking signal. Everything was new, I did some custom wiring (ign. boxes) and it all checked out. I reconnected the blue ground at the same spot as the black one and the car started and ran fine. Next day it didn't, MSD dizzy is shot. I think it was a coincidence that it started working right after I grounded the blue wire. I couldn't even find the wire in my electrical supplement (factory 87 service manual)
Axle/Gears: 3:23
![lol](https://www.thirdgen.org/forums/images/smilies/lol.gif)
Thanks for the quick info!
Axle/Gears: 3:23
Well, i replaced the MAF power relay with one a friend of mine had, and the burn off looks to be working because i can hear the "tick" and the fine wires glow red inside the MAF. Dont know what else it could be. I took a multi meter to everything as said on all the threads here on TGO so im pretty lost
I connected my blue wire to ground, thinking it was causing my issue. Nothing stared burning or smoking and it's still connected. I'll try and find out what this wire is. Maybe it's something fir a manual car?? Mine's an auto, what was yours originally?
My 88 5 speed doesn't have the blue wire taped up there. Haven't checked my 88 L98 auto
Axle/Gears: 3:23
mine was orginally an automatic but then i swapped it out to a T56 just recently
Axle/Gears: 3:23
I hooked it up took it for a drive and the car went into limp mode again, so much for that! I still wanna know what that wire is for though ive done a lot of searching and simply couldnt find out what it is?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
What do you mean by "limp mode"? Just a minor lack of power, or almost not willing to accelerate?
Axle/Gears: 3:23
It was an intermittent problem before and now i cant drive it down my street without it happening. Ive searched ALL the threads here on the board and tried all of it besides replacing the relays. The burnoff is working. I switched my old MAF power with a spare used one and hasnt cured the problem.
One thing i remember is when a vacuum line came loose on my car at the throttle body it would always make a "hissing" noise before i shut off the car. I hooked it up a long time ago, but i unhooked it again to see if there was any vacuum and there wasnt? i checked my vac lines and they are all intact so i dont know what the deal is with the low vacuum? Possibly clogged? I would imagine that would set off a different code though
Engine: that I like
I think we both have the exact same problem then. I've been chasing it for years. Just about everything has been changed/swapped/modified except for the TPS and the engine wiring harness. A speed density swap is sounding appealing right now.
Axle/Gears: 3:23
![Stick Out Tongue](https://www.thirdgen.org/forums/images/smilies/tongue.gif)
Engine: that I like
Yep, years![lol](https://www.thirdgen.org/forums/images/smilies/lol.gif)
It wasn't so bad when the car was stock, it would just lose a little power and throttle response. Then after the built 350tpi was installed (and custom chip), it would be basically not drivable when it would act up. But it would only do it if you started driving the car before it went into closed loop, so it was avoidable.
Then came the T56. For some reason, it would act up whenever if wanted to. No rhyme or reason to any of it. So I then had the chip modified for use with the manual tranny, and had the code 33 disabled completely. It was fine and dandy for a couple months, then out of the blue, it started freaking out again. I really can't drive the car at this point. Hopefully one of us will figure something out
![huh](https://www.thirdgen.org/forums/images/smilies/huh.gif)
Axle/Gears: 3:23
Then came the T56. For some reason, it would act up whenever if wanted to. No rhyme or reason to any of it. So I then had the chip modified for use with the manual tranny, and had the code 33 disabled completely. It was fine and dandy for a couple months, then out of the blue, it started freaking out again. I really can't drive the car at this point. Hopefully one of us will figure something out![huh](https://www.thirdgen.org/forums/images/smilies/huh.gif)
From what i read most people are fixing their problems by replacing the relays, cleaning MAF, or have found something in the wiring which i havent. So im going to try relays and see what happens. I think faulty relays will cause intermittent problems for awhile before they just die.
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
I was reading the posts and got curious about that wire myself and I went and looked just before typeing this and my '89 2.8 Firebird 5- speed has the wire on it also tapped . So not just the TPI cars have that wire .
Axle/Gears: 3:23
If we get the answer to the mysterious blue wire and my code 33 problem this will be a successful thread!
I went out and tested my TPS again, because i had someone else adjust it since at the time i didnt know how to.. i backprobed it and it was reading .63VDC at idle!!! shouldnt it be .54 from what i read? If thats causing my code im going to be embarrassed.
Axle/Gears: 3:23
So ya, it was my TPS.. how embarrasing is that
Just for anyone who searches with these probs
![Embarrassment](https://www.thirdgen.org/forums/images/smilies/redface.gif)
Engine: that I like
Well dang, I've already checked that on mine. Glad you got yours fixed though
![Cool](https://www.thirdgen.org/forums/images/smilies/cool.gif)
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Good to hear you got it running right , now for the wire identification .
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
I have two 1987 Camaro's with 305 TPI, 5 speed, and no A/C, and this blue wire is connected to the same ground spot (G115) as the underhood lamp!!
I haven't figured out what it's for yet either, but I'm still looking!!
Tomorrow, I'll check my 1989 Camaro with 305 TPI and 700R4 to see if it's an auto/manual difference!!
Hello Twin_Turbo, and MParks!!
I checked my 1989 Camaro with 305 TPI, 700R4 and A/C, and this wire is not at the ground spot (G115) as my other Camaros above. There is, in the same area, a blue and a green wire connected to the A/C system though, and this may be the answer!!
I'll keep looking for the correct answer, and not just an educated guess!!
![my 2 cents](https://www.thirdgen.org/forums/images/smilies/twocents.gif)
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
It should be taped at the blower motor like on my car and MParks car and Twin_Turbos car if you have it .
Car: 91 Trans Am
Engine: LSA
Transmission: T56 AWD
Axle/Gears: 8.8 4.10
Of the 80 or so 3rd gen harnesses Ive disassembled, it's never been grounded. It's tied into the AC wiring, my guess is some sort of diagnostics for the circuit
Axle/Gears: 3:23
Hey guys, i hate to say my car is playin tricks on me. Went out cruising yesterday, about an hour drive to my destination and back. I got there just fine, about half way back my car set a code 33 again. Man was i pissed. adjusting the TPS helped for those couple days any ideas?
Im glad to see people are looking into this blue wire ordeal, i hooked mine up with no results.
Axle/Gears: 3:23
Heres what i found, theres a ground strap that goes from the firewall to the back of the block on the passenger side. It also has two ground wires coming from the same harness as the burnoff, power for the MAF. If those grounds were loose, that would cause an intermittent problem right? Besides that, the bolt that they were on was loose coming out of the block so i tightened it, put a nut over it because there wasnt one thats why they were loose. What do you guys think?
This blue wire is grounded at (G115), which is the same grounding spot as the underhood light wire on my two 1987 Camaros without A/C, but on my 1989 Camaro with A/C it's not there!!
Hello Pocket!!
It's strange that you haven't seen this wire grounded at (G115) before, my two 1987 Camaros are bone stock, and one of them I've owned for 22 years + !!
My two 1987 Camaros are made in different factories also, one in Norwood, and the other in Van Nuys, yet they are both built with that wire grounded at (G115) with the underhood light!!
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Hello All!!
The blue wire is for the A/C system's "Fan Control Switch" (Pressure Switch), if however, you don't have A/C, the blue wire gets grounded, and the closest ground, without using a new ground point or a new bolt, is the underhood lamp ground (G115) point.
It seems that either a "TSB" or a "rethink" of the need for it to be grounded led to the wire eventually being just taped off, as opposed to being actually grounded!!
P.S. I found this circuit diagram in a Haynes Manual from 1987 in the new supplement: Revisions and information on 1985 through 1987 models. It covers the 2.8, 5.0, and 5.7 engines with the same explanation!!
ECM pinout C9 for the 2.8, and ECM pinout D11 for the 5.0, and the 5.7!!
The underhood wiring harness's for the non A/C cars had all the connectors for the A/C system, (at least mine do) and makes it cheaper for GM to produce due to commonality of parts thinking!!
![good idea](https://www.thirdgen.org/forums/images/smilies/goodidea.gif)
![thumbs up](https://www.thirdgen.org/forums/images/smilies/thumbsup.gif)
I figured out what the blue wire is. I had an issue w/ my 87, the ECM controlled fan would be running as soon as there was a distributor reference pulse. Decided to pull the wire and see what happens and whaddayaknow.... without it grounded the fan doesn't come on, as soon as it's grounded whammo... dr. side fan on. It may be part of the wiring for a single fan setup then.
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
That would go with what 87IROC-DAN61 said about it being for the fan control on A/C cars and it gets grounded on the non A/C cars .
