Are our window switches DPDT switches?
Here's the deal, I have a small piece of crap plastic DPDT on-off-on switch for my exhaust cut out. It's got 6 connections on the back. There's some generic switches at Radio Shack that would do the same thing, but I want to buy a power window switch, and mount it in the console to match the other switches. But.....our window switches only have 4 connections on the back. I'm NOT an electronics guy, but are they not a DPDT on-off-on switch?
Anyone see where I'm going, and have any info? Ideas?
Re: Are our window switches DPDT switches?
Yes, you're right!!! LOL, actually I just read that often times the reverse polarity will be switched internally, which of course, you already knew!!!! Thanks for the quick response.
...so basically I just need to buy a window switch, figure out which prongs are which and then wire it up, correct? Should work, right?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
+12V is pink and white, ground is black, blue and brown are the motor.
Car: 89 camaro rs
Engine: 468 bbc
Transmission: powerglide
Axle/Gears: 373 S-60
1 Post
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
You should try austinthirdgen.com for a good wiring diagram
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
But if you're needing to know because you do not have the original wires or plug...
Take the swicth with the picture of the window facing up and rotate it around to see the terminals. They should be at the bottom and to the right.
Wires should be,
black pink
tan blue
I would do it as a picture but they never come out right for me!
tglennon11
Interior Parts Wanted
09-11-2015 10:25 PM
