Where's the Horn Dude?
1 Post
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
This is probably a Stupid question:
I have a 1982 Sport Coupe. Where is the Horn Physically Located? If you can't tell me that, can you tell me how to identify the wire? I have just replaced my Steering Column and i tried out the Adapter kit that i bought to put on the wheel and have a working horn. When i put the hardware on and touch the lead to the adapter block, i hear an electrical Click. That means that the circuit has been completed, but what i should hear instead is the Horn. What should i look for next?
BTW, does the 1982 have a computer AT ALL? Hopefully the answer is no.
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Where's the Horn Dude?
The actual horn is in front of the driver side wheel, in the fender. There may be two in tandem, my 89 has two. Should be a single green wire going to each.
1 Post
Thank you........ Looked at your Avatar. I guess you're a Bubble Head. I did my time on a Tender. It was Orion AS-18, but that was a VERY long time ago.
1 Post
I went outside and found it!! thanks! Someone connected a YELLOW wire to it and it goes through the firewall and ends without being attached to ANYTHING in the car. Now, I need to know what wire on the Column to connect it to so that my horn will work on the steering wheel.
1 Post
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
yes it has a computer, the carb is computer controled, it has a map sensor, a throttle position sensor etc etc
also if its the stock 3 speed auto its a th200c not a th350, unless someone did a conversion .... i got a th200c that works laying around
1 Post
Looks like a 700r4 to me, but I'm no expert. The Carb is aftermarket. It's an Edelbrock 600CFM. This car has been hacked, and Hacked, and hacked. When i found the horn, they had just wrapped the bare wire around the male connecter on the horn. I can't believe they didn't spend like $0.30 to crimp on a Female Connector.
I used to be, I've been retired 10 years and have a civilian job now. Did 11 patrols on 3 boats (all SSBN) - Pulaski, Alabama, Ohio, as well as two years forward deployed on a bathymetric survey ship (T-AGS-38, USNS Hess) collecting data for submarine navigation.
1 Post
the 700 is bigger than the 200 ....... easy way is 3 speed for 200 4 for 700
i thought the early thirds had th350's when i first started messing with em (10 years ago) ..... but then i looked under it said thats no th350 looked it up in my book and duh it was the 200c
if you got a edelbrock than its no longer c.c. ..... the computer may still be under the dash
1 Post
No problem.
you were on the Alabama ........... its in my back yard at battleship parkway, i love going out to walk around it and the Drum
Not that Alabama The Navy has a habit of reusing names on their ships. The one I was on (SSBN 731) was the 4th with the name IIRC. The guys that rode those sewer pipes like the Drum had big brass ones.
1 Post
alright, now all i have to do is locate the Horn Relay. If someone could tell me where and what to look for, i would be most appreciative.
1 Post
It's done, The Horn works. Now, hopefully, it still works when i attach the Steering Wheel. It looks like it will though. I removed the External Horn Button that someone had installed. I can't believe how lazy some people can be. I would much rather have a Working horn on the wheel than some Gaudy Switch that's obviously out of place on the dash. Sheeez!
