Adding a Tach.
Car: 1987 Camaro Sport Coupe
Engine: 2.8 MPFI
Transmission: 5-Speed Standard
Adding a Tach.
I have a 1987 Camaro Sport Coupe. The current gauges are, BIG: Speedo, and Fuel Level. SMALL: Oil Pressure, Volts, Water Temp.(all small ones are idiot lights)
I want to add a tach, and change all the idiot lights to actual gauges. I need to know what I need to do all this. I'll be adding a couple pods on the A-post so i can fit everything nicely.
Please, I am not familiar with changing gauges and could use the help!
P.S. Is it possible to keep the stock shift light AND add a tach?
Thanks!
Thanks!
Engine: 2.8 MPFI
Re: Adding a Tach.
what if i were to ONLY add a tach, and keep the idiot lights?
is there an easy way?
i don't want to swap clusters
Car: 84 firebird, 85 transam
Engine: 350 SBC Or 7.07 Tonys,305stock
Transmission: Big Ugly, 700r4
Axle/Gears: 4th gen rear disk 3.42 lsd,9 bolt
Re: Adding a Tach.
Engine: 2.8 MPFI
Re: Adding a Tach.
Thanks for the advice, however. I would like to ADD an aftermarket tach. thats it
Re: Adding a Tach.
You want both stock and aftermarket to work. Just takecluster out fallow tack lead to the plug and piggyback the lead green wire from aftermarket tack and both should run at. Same time
Engine: 2.8 MPFI
Re: Adding a Tach.
Iwas under the impression that the sending unit will only work for an idiot light. And it's a different type for the actual gauge
Engine: 2.8 MPFI
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Tach Welding
No sending unit is required.
Connect the aftermarket tach to the coil primary (the primary side opposite of the ignition).
Happy Racing!
Make Noise, Turn Left, Repeat
Happy Racing!
Engine: 2.8 MPFI
Re: Tach Welding
Sorry, I mixed up two of my threads.
That one was going on about a temp gauge:P
sorry for confusion.
Car: 84 Camaro
Engine: In line 4
Transmission: 4 speed
Re: Adding a Tach.
yes I have installed 2 tachs now in my camaros and it is really simple it is just a madder of finding the neg side of the coil and hooking up your pos wire. also for the light because its a bitch to hook it up I just made it to when I turn my key to the on position it comes on. I also just used a sunpro tach that was for muti # cylinder motors. If you have any further questions just message me.
