wireing issue possible bad cpu
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
so i was driving last night and ended up dragging part of the harness that runs along the k member. all the wires got shredded. cleaned up the wires best i could. spliced new in that section of the harness. pulled all fueses and checked they are good.
here is the deal. im thinking the computer pooped out. tried to jump the a-b terminals and no fan comming on no check engine light is comming on when u turn the key on.
engine will crank but no fuel pressure. no power at the fuel pump relay at all. i checked every thing i could think of on the side of the road before i called the tow truck.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
ECM DOA
Once you verify you have the wiring reestablished if the light bulb isn’t burnt out, replace the ECM.
Happy Racing!
I Didn’t Wreck, The Track Moved
Happy Racing!
