changed the remote switch module (resistor), and no instrument panel lights !!!!!
ok guys here i come again with this problem, i had changed the remote dimmer switch and poped a fuse in there, 5 amps, my instrument panel lighted up for like 2 minutes than blew the fuse, now i poped a 10 amp fuse in there (cause i ran out of 5 amps ) and the fuse didnt blow but No lights on the dash!!!!, i thought i blew the resistor again so i went today and got another one and installed it,( another 60 bucks) and still nothing and the new 5 amp fuse dosent even blow, but i still get no lights, can someone please help me solve this problem, im getting very frustrated, thanks..... its a 91 firebird.
Car: 1991 Firebird Formula WS6 T-5
Engine: LB9 5.0 Liter F.I.
Axle/Gears: 3.08
Re: changed the remote switch module (resistor), and no instrument panel lights !!!!!
If anyone can help out with this we would both appreciate it, I am having a similar issue! Dash lights went out, checked the fuse it was blown. Put in a new one, it blew.. put in a bigger one cause I ran out of 5's and it didnt blow but no lights.. any help??
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Let’s Get Some Light On The Subject
It sounds like with the introduction of the 10 amp fuse you blew a circuit down the line.
Use a test light (for testing for voltage, not a continuity tester).
Open the line at the output of the dimmer module and place the test light there.
Does the module operate the light?
Happy Racing!
“I Didn’t Jump The Start, The Flagman Was Late”
Ghettobird52
12-29-2023 08:23 AM
