Speedo not working
Speedo not working
i have a 87 trans am 305 tpi , and my speedo dows not work , everything else does tho , i took it to autozone to run computer and the said that my speedometer sensor i think does not work and that is why im guessing it doesnt work , where is this located ?? i think it is in the trans which i need to replace anyway. and could this be the only problem ?
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Keep It Floored, The Speedometer Stills Says Zero!
Yes it’s located on the transmission.
You could listen to it or watch it with the right equipment but it’s 99% certain it’s the problem if they used the proper method to get a code 24.
Happy Racing!
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. WLow performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime and the nitwits that need headlights for a little rain
Transmission: 765R4
The VSS might not be included as part of the rebuild depending on the shop.
However it’s not expensive, and it attaches to the outside of the tranny.
Just tell the tranny shop you need a new VSS.
Happy Racing!
Happy Racing!
Transmission: 765R4
Yes it is.
There’s only one bolt that has to be removed.
Happy Racing!
Happy Racing!
Transmission: 765R4
That’s consistent with a bad VSS.
Happy Racing!
Happy Racing!
beachrodder
08-07-2015 04:27 PM
