New member and need some help
First off hi,
I just bought an 84 camaro 2.8l auto, with a bad starter, i replaced the starter already, but when i jump the solenoid, the starer spins, but the thing that pushes the starter gear to the flywheel isnt doing anything. the starter gear just spins w/o making contact.
Also, there was an alarm system on it that apparently was "going haywire" according to the PO, and their solution was to simply cut the wires to the loudspeaker. Yeah, that whole system's been ripped out.
From the looks of the ign lock, somebody tried popping it with a screwdriver at one point, considering the key BARELY fits it anymore, and you have to fight it to turn the key. Have a new lock set, that will be installed hopefully tomorrow.
Does anyone have a wiring diagram for the steering column? or any other ideas or info so i can get this freaking thing running?
Oh, and here are some pics
Re: New member and need some help
Hi There!
I started out with a 2.8 Berlinetta, great motor, never tapped rattled or smoked.
Not sure whats going on here though - is it a second hand starter or new one?Defiantely the correct one for the vehicle? Sometimes you need to shim them to get it to line up properly but I would think it should still engage.
Anyone else have any ideas?
Rob.
Rob.
It is a new starter that i got from advanced. (after 2 trips, they gave me the wrong one the first time). right now it is shimmed, as the original was shimmed i put the shim in with the new starter.
Thought i might have a flat spot on the flywheel, so i removed the dust cover, and everything there is fine. while i was under there i had a friend crank the starter, and the gear spins, it just doesnt move out at all to grab the flywheel, just spins at the bottom of the post.
Im thinking the old alarm system is messing with something, thats preventing the starter from doing its thing. going to mess with it some more this week.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Startling Development
The alarm system has nothing to do with it.
The new starter sounds defective.
Bring it back, let them throw 12 volts on it so they can see and they should replace it.
Have them throw 12 volts on the replacement so you don’t have to R&R another defective unit.
Happy Racing!
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime and the nitwits that need headlights for a little rain
Re: Startling Development
im gonna pull it next chance i get and see whats up with it. knowing my luck its not hooked up right or some stupid BS like that. if i cant get it going by monday, im just gonna say f it to the 2.8 and pick up a 305/350 and trans out of the local pick and pull
Pac J
05-17-2020 10:44 AM
92rsvortec350
19
10-09-2015 09:39 AM
LT1Formula
10-08-2015 08:34 PM
