World's Best DIY Immobiliser for Dummies
#51
Re: World's Best DIY Immobiliser for Dummies
Thank you for your prompt replay and for your help. Appreciate it.
DPCO is Double Pole Change Over, which is equivalent to DPDT relay according to Wikipedia http://en.wikipedia.org/wiki/Switch,but thats not an issue i can get the same DPDT which you used.
One thing im not understanding here is about the reed switch, when the reed switch is on the circuit is on, but as soon as you remove the magnet the reed switch will turn off which will turn the whole circuit off, isnt that correct? or the reed switch stays on after i remove the magnet? if the reed switch would turn off after you remove the magnet then how will the circuit remain on?
Thanks once again for helping me out.
Kind regards,
Yazen
Kind regards,
Yazen
#52
Car: 1988 GTA
Engine: 400 CI
Once the reed switch is activated, it stays activated until you push the reset button.
#56
Will try and build the circuit over the weekend and would share the picture with you guys!
I have an idea to improvise the device and would like to share it with you for your opinion and suggestions, if i install a time delay relay before the rest switch and hock it up with the door switch, and set it the timer to 2 minutes, wouldnt that be a good idea, so the scenario would look like this:
Get in the car, swipe the magnet, device is activated now, when i open the driver's door, the door switch would trigger the time relay and after 2 minutes the time relay would activate the rest switch and the car would turn off. This way i dont have to press the rest switch every time i left the car, and its good in a way if someone forces me to leave the car, so i leave the car, the car will shut down in 2 minutes. This way i dont require LED. What do you think?
Thanks, Yazen
Thanks, Yazen
#57
Car: 1988 GTA
Engine: 400 CI
I would keep the LED both as a deterrent and so you can see when you have successfully activated the reed switch.
As far as the door switch triggering the reset, I live in a warm climate and frequently start my car with the door open, so that wouldn't work for me. Also if you ever open your door for a second for some reason, like to let your dog into the car after chasing him around the neighborhood or say if you dropped some change at the drive-through, or you switch drivers with the car running, your car will die 2 minutes later. Then there would be the servicing issues.
#58
Thank you for your reply. Actually, you are right, its not a good idea! what iam trying to achieve here is to get the rest switch to be activated automatically, maybe i can connect it to the ignition switch and whenever the switch would turn off it would trigger the reset switch! what do you think?
Regards,
Yazen
Regards,
Yazen
#60
Hello guys,
I finally bought all the items, bench tested it and it worked pictures of items attached here.
The only question i have (for now ) is that, how to hook up the reset switch with the ignition, so that as soon as i switch off the car, reset switch would be activated to arm the device? i guess it requires a relay! but which kind of relay is it, i dont know guys your help is needed please.
Thanks again,
Yazen
Thanks again,
Yazen
#61
Car: 87 IROC-Z
I like my immobilizer the best. You cannot start my car without lightly tapping the right side of my shifter
#62
Car: 1989 GTA WS6
Engine: 5.7L TPI
Axle/Gears: Borg 3.27
#63
THANK YOU! Sorry for shouting but I have been searching for a clear wiring diagram for this system & you provided it.
James
Brothers Hotrods
James
Brothers Hotrods
#65
Did you use a momentary switch to set the alarm? I have a press on (close), press off switch (open) & I have to press the switch to off (open) & then swipe the magnet to disarm system.
It sounds from the original operating instructions that you can have the system armed & simply swipe the reed switch to disarm the system.
please advise.
thanks J.
Just noticed you live in Sarasota, FL. Almost moved there with my Colombia born wife. (now ex-wife) We searched from the Cape, around the horn up to Tampa, liked Sarasota the best.
please advise.
thanks J.
#66
RE: the reed switch. I one have has three connections. a feed (input) post, and two output posts, one of the output post is active when magnet is away from switch & the other is active then magnet is close to switch. If I remove magnet it changes posts. Have it connected to pole that is active then magnet is close to switch.
Did you use a different kind of reed switch that stays closed even if magnet is taken away?
thanks
J.
thanks
J.
#67
1 Post
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
This is a pretty cool Idea and i might just put it in my car
#69
Car: 1988 GTA
Engine: 400 CI
Yes, it is a momentary switch. As soon as you press it the LED comes on.
That is correct. When the magnet closes the reed switch it stays closed as long as current is going through it.
#70
Car: 1988 GTA
Engine: 400 CI
Hmmm...I assumed the reed switch stays closed but I'm not sure. I believe the current holds it in place. I can tell you that I only have to swipe the magnet passed the reed switch and when I do I can actually hear the relay under the dash click. Maybe just the relay stays switched until the current is cut. The magnet is in my key fob so after I swipe it it then goes up to my ignition so it definitely doesn't need to be in contact.
My reed switch only has two contacts and is either connected or not connected. .
#71
Car: 1988 GTA
Engine: 400 CI
Car: 1988 GTA
Engine: 400 CI
HoosierinWA
10-07-2015 10:15 AM
Damon
09-26-2015 04:29 PM
88, automotive, building, camaro, car, diy, fbody, fuel, immobiliser, immobilizer, magnet, magnetic, pump, reed, switch
