dash lights ( cluster )
Car: CAMARO,GMC SUBURBAN DUALLY,RACEBOA
Engine: 305 TBI( soon 383),350Vortec
Transmission: 700 turbo
Ok, i got everything working on my 3rd gen. ONLY THE FREAK'N INSIDE LIGHTS !!!!
They just don't work,,,fuse is ok, gray wire on radio not groundet, radio works.
WTF,,,,need help !
WTF,,,,need help !
Re: dash lights ( cluster )
The power comes from the tail fuse into the light switch, and then it comes out with a green wire to the INST fuse. Have you got 12V at both sides of the INST fuse? Check the ground under the drivers side of the dash... It'll be up near the steering column.
ambainb
04-25-2016 09:21 PM
