FAN SWITCH RELAY ???
Old 01-07-2010 | 03:44 PM
DAREDEVIL 1's Avatar
Car: CAMARO,GMC SUBURBAN DUALLY,RACEBOA
Engine: 305 TBI( soon 383),350Vortec
Transmission: 700 turbo
My electric cooling fan is not working, but when i hot wire it it works.
Where is the relay ???? 1988 camaro 305 engine.
fuse is ok.
Just can't find where the relay is located ! mmmmhhhhh
Thanks for any help.
Old 01-07-2010 | 04:17 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
Re: FAN SWITCH RELAY ???
mine was next to the battery mounted on the support for the radiator.
to find it, grab the wires that power the fan.
follow them up to the next thing they come in contact with.
that next thing will be the relay
Old 01-07-2010 | 04:45 PM
Iroc-Dennis's Avatar
Car: camaro iroc-z
Engine: 355 L98 Corvette engine
Axle/Gears: 3.27 9 bolt borg warner
yes my relay was located there to!
do you have a single or dual fan setup?
if you have the dual there must be 2 relay`s.
dennis
Old 01-07-2010 | 05:29 PM
Thats the funny side....single fan,,and if i follow the wires they go into a big harnes. NO RELAY !!!! mmmmhhhhh
Old 01-07-2010 | 07:18 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Driver side firewalll between the brake booster and the fenderwell - there os a bracket held to firewall with 2 10mm screws - the relays are on the inside of that bracket. The one with the large black with red stripe wire is the fan relay, the other is the fuel pump relay.
Might also test the fan switch, located pass side head between #6 and #8 cylinder - has a single wire connector - squeeze connector to remove - ground this connector with key on to see if fan runs - if fan runs with this connector grounded and key on, then the relay is fine, and the fan switch is bad.
Old 01-07-2010 | 07:24 PM
Drew's Avatar
Look next to the brake booster on the firewall for the fan relay.
Old 01-07-2010 | 07:42 PM
THANKS GUYS...THIS IS WHAT A SITE LIKE THIS SHOULD BE AT ALL TIMES.
THAT WILL GET MY FAN GOING !!!!! I HOPE .
Old 01-07-2010 | 11:16 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
thats odd.
i have the two up next to the brake booster and i also have the one on the side of the radiator.
is it redundant?
maybe one was for the AC or something?
Old 01-08-2010 | 01:03 PM
Ok, found out therakay was bad,,but. it turns on when i turn the ac on...now i need to find out if it will with the ac off.
So it could still ba a bad switch ( temp switch ) .
Also the gauge still does not work. I will get it done though .
THANKS FOR ALL THE HELP.
Old 01-08-2010 | 02:09 PM
Car: 1992 RS
Engine: Carbed 350
A/C on will run the fan automatically - so yes the fan switch itself could def be bad. Careful replacing it - you'll get coolant in the face!
Old 01-08-2010 | 03:21 PM
Checked out the gauge ,,,same thing....if grounded out. PEKS all the way, so i think i replace that sender as well.
LOTS DO TO ,,,saturday is a LOOOOOONG day . LOL
Old 01-08-2010 | 03:35 PM
Car: 1992 RS
Engine: Carbed 350
At least it's warm enough there to work - I have sat off, and with a hi of 33, I'll be inside cruisin TGO!
Old 01-08-2010 | 03:39 PM
They thoguht we gonna get snow this weekend in Florida,,talking about warm enough ????!!! LOL
Hopefully the sun will find its way back FAST !!!!!!!
my86bird
10-23-2015 12:20 PM
64goatman
09-09-2015 01:09 PM
Gunsbee
09-07-2015 07:10 PM
scotrans am
09-05-2015 04:26 AM
85Special
09-03-2015 04:21 PM
Quick Reply: FAN SWITCH RELAY ???
