QUESTION ABOUT WIRE ?????
Old 01-04-2010 | 12:25 AM
DAREDEVIL 1's Avatar
Car: CAMARO,GMC SUBURBAN DUALLY,RACEBOA
Engine: 305 TBI( soon 383),350Vortec
Transmission: 700 turbo
Hi, i am new and there is a wire on my 88 Camaro behind the AC compressor, that leads off of that wiring harnes that plugs in the compressor.
It is a round plug on the end with 2 leads ( its light blue ). WHAT IS THAT FOR ?
The previus owner had it hot wired with a metall pin .
I want to hook it up the correct way but can't find where it would plug into.
Also, excuse my english. LOL
Scott
Old 01-04-2010 | 02:49 PM
Re: QUESTION ABOUT WIRE ?????
So ....nobody knows what this plug is for and where it goes ?????
Funny !!!!
Old 01-04-2010 | 03:22 PM
Drew's Avatar
It sounds like you're describing the harness that plugs into the A/C pressure switch in the hardline running from the evaporator to the condenser. It's part of the radiator fan control system. If it's grounded,that should make the fan run anytime the key is turned to run. Look down on the passengers side frame rail and you should see the connector.
It could also be the harness that connects to the condenser, but that'd be a large round black connector with a green and black wire... Jumpering these two wires would make the A/C compressor clutch engage full time.
A pic of the plug would help, but if it's a blue weather pack, round in shape with a gray and black/white striped wires, it's the pressure switch.
Old 01-04-2010 | 05:49 PM
A pic of the plug would help, but if it's a blue weather pack, round in shape with a gray and black/white striped wires, it's the pressure switch. If it's black, huge
Thanks, i think u are on the right track with the fan switch.
Just replaced the fan, but not done yet completley.......the fan motor was burned up.
I just bought this Camaro and work on Boats and my Suburban,,,but this is something new to me.
Thanks for the help.
I will post a pic tomorrow, maybe u could post a picture of where it goes ?LOL
PS.: its like i said , light blue and maybe the diameter of a penny with 2 wires.
Scott
Old 01-04-2010 | 06:09 PM
Drew's Avatar
The diagrams are pretty messy in the books, and the plug is burried in a complete car... But try this...
Old 01-04-2010 | 07:00 PM
NO,,,mine actually is right behind the compressor. On the valve cover kind of .
The plug is round and not square.
I get a picture now,,,,hold on.
Old 01-04-2010 | 07:13 PM
Here are some pics of the plug i am talking about,,,ok....lol...not light blue, black and the wires are light blue and green. HAHA
Attached Thumbnails QUESTION ABOUT WIRE ?????-camaro-006.jpg   QUESTION ABOUT WIRE ?????-camaro-004.jpg
Old 01-04-2010 | 08:10 PM
Drew's Avatar
It plugs into the back of the a/c compressor.
Cleotiz
01-06-2018 08:56 PM
Caspar
06-19-2016 11:19 PM
Bryan F
08-18-2015 02:28 PM
86IROC112
08-17-2015 07:57 PM
redmaroz
08-16-2015 11:40 PM
Quick Reply: QUESTION ABOUT WIRE ?????
