spaghetti factory wiring.. 1984 berlinetta
Car: 1984 Camaro Berlinetta
Engine: currently 2.8l v6
Transmission: not sure.. its a 5spd
Axle/Gears: don't know but it will be replaced
hey guys! I bought a 1984 berlinetta.. i wish i did my home work on the car and looked around in it before i bought it so quickly but for a running car only $750 i can afford to fix a few extra things.. but still like to keep costs down as much as possible! well the biggest problem is in the engine bay and even in the cab at the fuse box wires are pulled or spiced micky mouse must have bought a spaghetti factory and trough a dish my car and that mess resembles the wiring... like i have a wire that was cut in half they'er idea to fix it was by using little clamp ends with spring on both ends of a 3' wire to fix the connection and thats the wire that turns the engine over like who does that! .. well i bought this car with the plan to turn it into a street/strip car i want to have it doing 11sec in the 1/4 mile but be able to drive good on the road.. i also want it to look nice! but looks dont mean anything when i know whats lerking behind the dash!! so i dismantled everything the dash as you know the top part comes off well the corner edge driver side was banged and broken i want to re think the entire look of the car meaning new style dash and new tacs i hate the original look! so my question is what dashs will fit from other camaros and what year?? also im re wiring my entire car!! so where would i go to get a complete new kit for my entire car... i mean fuse panel wires running to the head lights and tail lights and everything between.. thanks for reading and hope to hear from you!!
![driving](https://www.thirdgen.org/forums/images/smilies/driving.gif)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
Re: spaghetti factory wiring.. 1984 berlinetta
Berlinettas are in a league of their own. Most of the parts you are replacing are specific to them. Whatever donor car you pull from, grab the dash harness and if possible, the engine harness. The console and column also need to be swapped
![yup](https://www.thirdgen.org/forums/images/smilies/yup.gif)
If you want to swap a "regular" Camaro dash and remove all the Berlinetta stuff then be prepared - it is NOT a quick or easy project. Just about everything in the interior will need to come out and much of it will need to be replaced. This includes the Center Console, Dash Housing/wiring, Steering Column, and entire Heating / AC system. ( Internal and external heater box is OK - but the Heater wiring harness needs to be swapped. ) You can still use your original engine bay harness but will need to splice the wiper system because those wires will not match up at C100.
Your BEST OPTION for a conversion is to get a complete donor car from 84-86 as they will be the most compatable with your 84 Berlinetta. If you prefer the 90-92 style interior you will need to cut or drill out the dash housing support brackets from each side and install the 90-92 version.
http://www.ronfrancis.com/prodinfo.asp?number=XP-66
And they emailed me back saying it would be about $500 what a great deal!!
Car: 92 Firebird
Itll be easier to swap in the donor harnesses than to figure out a way to mount that setup
![Cool](https://www.thirdgen.org/forums/images/smilies/cool.gif)
manifoldsrme
09-17-2015 11:40 PM
Saxondale
Exterior Parts Wanted
09-16-2015 06:32 AM
CAMAROBEAV
European Region
09-12-2015 09:34 AM
