Specs on Purolator electric fuel pump
Car: 1986 IROC-Z28
Engine: 5.7L L98
Transmission: 700R4 OD
Axle/Gears: B&W 3.27 Posi- :D
I found out that my camaro has this "Purolator Universal Electric Fuel Pump". It says it works with my carb setup showing strictly not to use with fuel injection systems. I just can't narrow down which one mine is, because i cant see a part number on it except "pro#125" or a place that shows specs on any of them. has anybody heard of these? i think the most powerful ones put out 9 psi tops for pressure, i dont know what mine is pushing and/or if it is adjustable. sorry if i sound dumb or confusing.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Speed Reading
Did you read the P/N correctly?
If it’s the PRO 12S the PSI is approximately 5.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime, and the nitwits that need headlights for a little rain
Happy Racing!
Car: 1986 IROC-Z28
Engine: 5.7L L98
Re: Speed Reading
well that was the only number i saw on the side with the maker label, and yes it was pro 125, but yesterday me and a buddy noticed that the ( i forget what part they are ) little brass or copper looking nipples in those rings in the front barrels of the carb, one side was dripping real fast and i had my regulator set at 4psi? maybe its something with the carb?
beachrodder
08-25-2015 08:05 AM
92camaroJoe
08-13-2015 06:07 AM
