where to get bracket for cs 144
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I would like to upgrade but they dont make the bracket anymore
is there anyone who is making this braket
I dont think the jy out here are going to have it. they crush everything
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: where to get bracket for cs 144
do you have a serp system or v-belts? I have v-belts but the belt for the alt is serp (ribbed style). My alt is on the passenger side. I think I was able to mess with the existing bracket to get it to fit. It is a bigger, so I unbolted one of the two bolts that hold the bracket to the engine, that way I could move the bracket up some and bolt down the alt...
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Look for a 93 9C1 Caprice cop car. They had a bracket made specfically for the CS144. I have one somewhere around that I used for a while. Then went with tall valve covers and it wouldn't clear. Doesn't matter much now since I now have a march mid mount setup. lol
Car: 1987 Trans Am
I believe the CS144 and the CS130 are similar if not the same externally, so any vehicle (ahem, LT1) with that style alternator should be able to be used...
Engine: 350 tpi
hey kat I also have tall valve cover because I use polylocks to keep my rockers in adjustment
the cs 144 will not work with tall valve covers?
let me know
let me know
Engine: 350 tpi
I found a part on ebay that might work and I was wondering if you guys could take a look and tell me if it is right or not
http://cgi.ebay.com/ebaymotors/88-89...Q5fAccessories
let me know
thanks
let me know
thanks
Car: 1987 Trans Am
let me ask you this, do you have a serpentine belt? Because I just did a recent "upgrade" on mine, I removed the top alternator bracket and just put a turn buckle in its place (from Home Improvement, Lowes, etc)...
Car: 1987 Trans Am
hhmm, yeah I think it'll be "more difficult" to modify the serp settup as opposed to the vbelts like I have. Can you take a pic of your brackets. I need to see if the alt bracket is also part of something else (smog pump, power steering pump, etc)...
Engine: 350 tpi
let me know
thanks
let me know
thanks
now its time to make some braces
