Who uses a scanner?
Who uses a scanner?
Trying to find a good scanner for use with 80's GM CCC systems but no one really knows much about them. I'm not looking for a code reader, but an actual real time scanner that tells you all the info your ECM is seeing ( like TPS voltage, temp sensor reading, EGR on/off, dwell etc. ).
So what's a good affordable scanner and where's a good place to pick one up?
EDIT; I see I have posted this in the wrong section. I'm not used to your message boards having so many categories.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Re: Who uses a scanner?
I picked up an Autoxray EZ-Scan 3000 off ebay for $80 several months ago. I use it on my daughters '84 CCC 305 T/A and my car with '95 LT1 drivetrain.
I've been getting contradictory information on exactly what info this scanner will display in the old 80's C3 carbed cars. Care to share?
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
I've read that plugging it in disables knock retard while it's scanning. Either way it was no help to me a year or so ago when I was attempting to diagnose a spark knock/retard issue.
