Security bypass/ hotwire
Car: 1992 Firebird
Engine: 3.1
By no means am I in it to steal thirdgens but im looking to buying my second current firebird... problem is no key... and I want to hear it run obviously... also my 92 sometimes gets wacky and doesnt like the dealers key... they have it so you can have it in the run position but you cant start due to the security... does anyone know a way to bypass the security all togeather on a 91 or 92... I don't know if it makes a difference on the year of a thirdgen or not... I've been told its been done with a wire grounding out something... Any ideas?
Car: 1987 Firebird
Engine: 2.8l V6
Re: Security bypass/ hotwire
I have a bad habit of losing my keys, and i know im going to need to know.
1 Post
Car: proud owner of a 1987 trans am
Engine: turbo 355
Transmission: t5
i don't know bout yours but on my car if i just turn the ign really hard without the key it will still turn on this probably wont help but when all else fails force it
Car: 1992 Firebird
Engine: 3.1
it would have to be a quick fix... i dont think i have the time to try 15 different resistors haha
1 Post
Engine: turbo 355
Transmission: t5
O and i should add to make sure that if you do that you have to turn it back a little so the starter won't hang up
Car: 1992 Firebird
Engine: 3.1
well the guy can turn it to on position w some pliers but... security wont let it start electronically not force haha
Car: 1992 Firebird
Engine: 3.1
haha sux for u.... yea i see all these charts on here for the keys... does anyone have a way to id the resistor needed for each vats system like a number on the box for each of the 15 keys... so like key 1 matches this box code... that would be really helpful
Car: 1992 Firebird
Engine: 3.1
yea its a lil pellet in the key that has a certain resistance value to it... but... i dont have the key so i cant decode it
Car: 1992 Firebird
Engine: 3.1
i mean i could get all 15 but if u think about it... it takes five min to reset....so thats 75 min of trying.... UNLESS can u manually reset by disconnecting the battery????
Car: 87 GTA
The owner can take the VIN & proof of ownership to a stealership & they cut a new chipped key for that car.
Not the cheapest (because of the chip) but the only way I know of to get it started.
Car: 1992 Firebird
Engine: 3.1
well its for buying a car without a key so... i want to hear it purr before i buy... and if i can do that easily it would help... i dont wanna drag it to the stealership on the way home to find out i gotta bad tranny and a knock that sounds like rods are flying like bullets out of the hood lol
1 Post
Engine: turbo 355
Transmission: t5
that wouldn't be quick and thats not the only way to get it started ive seen plenty of car's with the chip in the key that have been bypassed by putting the correct resistor in between the vats wire's to fool the ecm i did it to my dads 96 bonneville i would hope you could do it to a third gen
Car: 1992 Firebird
Engine: 3.1
Car: 1992 Firebird
Engine: 3.1
1 Post
Engine: turbo 355
Transmission: t5
ok well i done it to an old grand prix one time i found the main wiring harness and found the wire going to the battery and the starter and connected them and wallah running car
Car: 1990 Camaro RS
Engine: Stock 305 TBI
i had the same problem.. get all 15 resistors, plug them in one by one and turn the ignition (if you can).. it shouldnt crank at all until you get the right resistor and then boom you got the right one when it cranks. you dont have to wait 5 minutes inbetween each one.. (or atleast i didnt) i made all 15 then went through them one by one and within 10 minutes i had it cranking and started.. if you cant get the ignition to turn to the crank position but can get it to the on position, hook up a light to the injectors to know when they are firing, turn the ignition to on, go by the brake booster and short a big red wire witht the big purple one (constant hot and starter wire) and when you have a resistor that makes the injectors fire you have the right one. they should fire right away once you get the right resistor in there just like the crank problem.
the easiest way to short the wires is with a sharp knife. just slice straight into them at the same time so the knife contacts both wires at the same time and there ya go.. that way you dont have to strip them back or cut them in half.
hope that doesnt confuse you too much lol.
formula00ra
Interior Parts Wanted
09-28-2015 11:50 AM
