86 TPI diagnostic port under steering wheel
Car: 1986 Iroc-Z
Engine: 305 bored .30 over
Does anyone have a schematic for where the wires run to from the diagnostic port? I have a yellow organish color wire that is cut, it is coming from position E. I cannot find the schematic for this diagnostic connector at all, not even in the shop manual. I think it is the ALDL port? thanks
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: 86 TPI diagnostic port under steering wheel
That's the serial data line. It also goes to M and connects to pin A8 of the ECM.
Car: 1986 Iroc-Z
Got it on A8 to ECM. You say to M, I have many connections labeld M so please enlighten me a bit more please. I have made the connection over to A8 and waiting for more of your knowledge. Thanks for the help. Tony
Engine: 5.7L/350
The M port on the ALDL connector (lower right I think). So A8 on the ECM connects to both the E and the M contacts on the ALDL connector.
backtothe80s
09-05-2015 12:39 AM
