VIPER alarm problems
Anyone have experience / knowlege of these???
My 92 convert has the VIPER alarm system that seems to have been installed on a lot of our cars. I recently had the battery disconnected for a couple weeks while doing some work and since I have reconnected the battery the alarm is going nuts.
The alarm was never programmed for passive arming, but now it passive arms alll the time and the shock sensor sets off the alarm every time I open or close the garage door.
I have the original manual which is no help, and I also searched online and printed out a more informative manual but this still tells me nothing about troubleshooting or reprogramming the passive setting.
Any ideas? (besides disconnecting the alarm or just not opening/closing the garage door!!)
1 Post
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
Re: VIPER alarm problems
you know the model number? you need to reprogram it none the less. register at The12Volt.com and you can browse alarm installation manuals. it's gonna be under "downloads" at the top header menu (middle row 2).
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
As far as the passive arming goes that can either be programmed with a Bit Writer or by using the programming button which you would have to locate, it is usually under the dash but all depends on the original installer.
I would just like to add that it is highly unlikely that the battery getting disconnected had anything to do with either of these problems. Perfect example I sold my old DD in January and I pulled out a remote start alarm before I let it go. It has been sitting in a zip lock bag in my closet. Just last week I put it in my new DD and it still had every one of my old settings programmed. It is a Viper 560vx.
The remote is a 2 button, left one marked I right one marked II.
The entire interior except dash front and pad is out - there is a componenet of the alarm that was under the console, approx 3" x 4" clear plastic and only about 3/8" thick, can see electronics inside and has an indicator light in the corner - I obviously know little about these, I thought this might be the shock sensor unit.
Thanks again for your help.
Car: 91 RS
Engine: 350 TBI
300 ESP has an internal shock sensor there is a little **** on one side that you can change the sensitivity with. So there should only be one module. The way the module is mounted is directly related to how it works. Example, if its mounted firmly to a solid surface the sensor is less effective because the "shock" has to carry though out the entire car. Best mounting can be achieved by securing it to something like a wiring harness because it doesn't have to carry though the whole car.
There should also be an LED and button. If you can locate those you can disable the passive arming. Just go through the feature programming sequence outlined in the manual.
Car: 91 RS
Engine: 350 TBI
Don't know, I will have to check. If it does I assume that is the sensitivity adjustment for the shock sensor.
When this thing was driving me nuts I disconnected all 3 wires at this module and the alarm just went off continuously - I thought if it had no power it just would not work.
Car: 91 RS
Engine: 350 TBI
DEI offers a back up battery for alarms, so if someone tried cutting your battery cables it would set your alarm off. If it is going off while you are diagnoseing it you could cut the wire going to the siren temporarily. The parking lights would still flash as the alarm was going off.
Or
Assuming you meant that you pulled all 3 fuses to get the alarm to quit, alarms can be tricky and pull power or ground through other wires instead of the main power ones.
Or
There is a white adjuster screw on the face of the module just above the small led.
As I think about this issue I do not think the shock sensor setting is the problem - setting worked OK when all the interior was in, the module was mounted on top of carpet under console - interior is out now except for driver seat so doors and floors are just bare metal with the module sitting on the tunnel so I am guessing it is just getting a whole lot more vibration now than when it was all together.
If the alarm would stop passive arming I would not have this issue so that is the real problem and apparently I need to reprogram it or just rip the whole damn thing out. I registered on the The12volt.com website and even though I sign in and it recognizes me I cannot access any PDF files to download - any suggestions on where else I can get this info?
