Series or Parallel
Old 05-15-2009 | 10:44 PM
vorteciroc's Avatar
Series or Parallel
For those of you that have replace your instrument panel cluster with a custom IPC using Autometer or other after market gauges...
I am installing a set of Autometer gauges in a Jimmy-Jams panel in my 87 Camaro. I have the pin-outs for the original IPC and i was wondering if all you you had wired the gauges in series or parallel being that there are several termianls on the connectors to supply power to the gauges. Also for illumination, did you all wire the bulbs or LEDs in series or parallel?
Old 05-16-2009 | 10:48 AM
vorteciroc's Avatar
Re: Series or Parallel
Bump
Elephantismo
02-13-2019 12:51 AM
PurelyPMD
05-05-2016 04:57 PM
sreZ28
10-22-2015 08:21 AM
3GZJerry
LSX and LTX Parts
10-14-2015 05:17 PM
92camaro350cci
10-14-2015 09:29 AM
Quick Reply: Series or Parallel
