door sill's with Led lights underneath?
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
Ok what I want to do is get custom door sill's that say Z28. I want to put LED's under it that are red to match my car. I want them to only come on when the door is open. any ideas how to go about this? pretty simple or alot to do? never done a elec. job.
Car: 1991 RS Camaro
Engine: 350 0.060" over
Re: door sill's with Led lights underneath?
Well, if you have to ask maybe it isn't your thing. On the other hand, I think it would be simple and something you could do:
1) Get LEDs
2) Determine the right resistor to pair them with for 14.8V (THIS IS MANDATORY)
3) Solder them together, put it in a clear pipe if you don't want to just stick them under there bare (also probably not an issue if you use shrink wrap)
4) Wire them to a door switch
If you want them to blink, that's a bit harder but doable. If you want them to do something complicated like do one thing when only your door is open, and something else when the passenger door is open, that's a bit harder.
1) Get LEDs
Axle/Gears: G92
1) Get LEDs
1) Get LEDs
Car: 1991 RS Camaro
Electronics Goldmine
Digikey
AllElectronics
Ebay
Digikey takes 24 hours to process you as a customer the first time but is good after that.
Most of those places have high shipping charges to cover their lower part costs so be sure to do one order not several.
Radioshack is generally VERY expensive for electronic parts.
Once more, LEDs MUST have resistors.
Digikey
AllElectronics
Ebay
Axle/Gears: G92
Thanks, Does anyone know a good place to get the tube? has anyone done something like this before and can show a walk through or a how to or something. I tried searching but can't find something similar.
Car: 1991 RS Camaro
Find a plastics place. Alternatively, McMaster-Carr, although that will be expensive.
Axle/Gears: G92
Thanks, I am gonna try this as soon as I can. Gonna start ordering what I want and Get it done sometime some. Thanks alot.
Car: 91 RS TBI 91 Z28 TPI
Transmission: wc T5
you can also get l.e.d tape check ebay for it.... Have seen it a t wal mart and other auto parts place's too.....all you have to do is supply power to it and ur done its flexible and quite thin.
Axle/Gears: G92
LED tape what do you mean? Can I have a pic for reference so I know what to look for?
Car: 1991 RS Camaro
Google is your friend:
http://images.google.com/images?q=led%20tape&sourceid=navclient-ff&rlz=1B3GGGL_enUS270US270&um=1&ie=UTF-8&sa=N&hl=en&tab=wi
It isn't to bright though.
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I am pretty sure it IS bright enough...the problem is that its not even... I currently have 2 of those strips (about 12 in each one) as my dome lights, they run parallel to the t-bar on my TA. Just 1 of those is brighter than the stock dome light... I'm not sure if it would work in your application, it really depends how big "Z28" is going to be, there is about an inch between each LED in those strips...
Car: 1991 RS Camaro
I was thinking bright enough to show up at night from under the door sill. If you only want to have it appear at night, or want it to appear red but not provide light, I suppose that would be plenty bright.
LED Lighted Door Sill Cover
Easy installation
Water proof
Elegant visuality
Magnetic system
Battery life for 3 years
Dual-lock connection
Stainless steel
http://www.chromelight.eu
http://www.ledlighteddoorstep.com
Water proof
Elegant visuality
Magnetic system
Stainless steel
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
http://www.dhgate.com/2x-3w-decorati...a4.html#s1-5-1
Found these a couple weeks ago, pretty relevant to this post.
1992 Trans Am
05-10-2023 07:19 PM
