i want to run dual batteries,,,need some help!!
Car: 1990 camaro RS
Engine: forged 383,8.7;1 200hp nitrous
Transmission: t56 6 speed
Axle/Gears: quick perfomance 9 inch with 4.11s
1990 camaro 305 tbi---i am having trouble with my car battery dieing when i run the stereo with the car off. i want it to last longer with enough power to crank the engine over. as of now i can only run the stereo with key off for about 3 minutes. ive heard of running dual battery but i am afraid of fire or shorting something out. ive also seen a cylinder looking thing that helps buy letting the stereo take juice from it instead of the battery directly...
any help will be very appreciated
thanks
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: i want to run dual batteries,,,need some help!!
Is Your battery old ? I can run my system which sucks alot of juice, got 2g hooked up to it, and it will last an hour easy semi loud.
3 mins battery might be shot :/
What are you pushing ?
Car: 85 Camaro IROC
Engine: 5.7 TPI
Axle/Gears: open rear, 3.42 gears
go buy yourself an optima red top.
get the biggest one autozone or whoever you go to will make fit.
then if you are still having problems, wire your old one in with it.
i agree that either your alternator or battery is on its way out though.
i can run my stereo (with key on and engine off, ie, not on stereo only circuit) for over half an hour without putting a dent in the battery.
granted this is on a brand spanking new optima, but it shouldn't be a problem for any decent battery.
i once left my lights on and remembered 3.5 hours later.
went running out to find that my lights, although not super bright were not out yet.
turned them off and the car cranked.
i love my good battery.
i guess if you are running over 1000w of power to more than 2 subs and have all your component speakers amplified as well and are running them all at high power, i could see you running out of juice, but really, i think you need a new battery.
Car: 1990 camaro RS
yes its very old but it is stillpushes out 12.57 volts off and 14.46 running
i got 2 fosgate 10 in subs with 2 amps one 60 and one 40 watt amp..all custom and done professionally...
i also bought the car and found out that it has blue neon underglow that i never use.
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
I am running dual batteries but I also have a 230amp alt with wire upgrade and I am running a 1800 and a 1200 4ch amps. I can run my stereo for a couple hours but what matters is the class of your amp not the amp output. If you have a class A/B amp it will be very power efficient compared to a class C or D and god forbid those Monster class D amps like the audiobahn 2300 that will turn a car off from just soaking the power.
Get a Optima yellow top but if you feeling frisky go for the blue top (Marine) and have power to spare. I am running two regular batteries but that is because I was cheap at the time but I will be going yellow top with a hell of a battery isolator just to be safe.
Car: 85 Camaro IROC
Engine: 5.7 TPI
with the amps you are running, you shouldnt have a problem with your battery.
get a new one.
if you are still having problems, run your old one as a backup
get a new one.
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
go to auto zone and get the free test so you don't go buying one thing and needing the other. i did it and its frustrating to drop all that cash when i did not need to.
Car: 1989 Camaro RS
Engine: LO5 350
Axle/Gears: 3.42 posi
the cylinder thing that you were talking about is called a compositor so you know and they are very helpful when running a lot of power from a battery. and just because your battey puts out 12.57 volts doesnt mean that its good. my battery did that and it had 214 cold cranking amps (CCA) and my car wouldnt start with the stereo on so i had to go get a new one. i got the optima red top and it is great i dont have any battery problems anymore and if you do i would buy a compasitor to see if the helps and if not you might have some other problem.
Car: 1990 camaro RS
alrighty thanks for everything i really appreciate it..doesanyonenow how to curcit two batteries together...i dont have the money far an optima and a compasitor just yet but i have a fairlynew top post battery i would like toaddtill i can afford the good stuff...
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
for dual batteries an isolator is used-basicly a big diode
that lets the electrical system charge the auxillary
battery, but does not let current from the auxillary batt.
flow back to the main battery or vice-versa, that way
the batts can't discharge each other.Battery isolator is
commonly used with campers and RVs.If properly done
and fused right dual battery system will be reliable and
safe.
safe.
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
12.57 volts off is quite low actually, 12.75 is considered 100%. What is the voltage with the lights on, and how long can they stay on before giving you trouble? 14.46 running is an indication that your alternator is working perfectly. I think you just need a new battery, or you can try to see if a long-term trickle charge will help some.
Car: 87 GTA
Power output has nothing to with load capacity/life length.
Even if it puts out GREAT power, that doesn't mean it is retaining any of it (holding a charge).
You definately need a new battery.
eightsixseven
08-14-2015 04:09 PM
db057
08-11-2015 11:11 PM
