Best Damn Alternator.....Please!!!!!!!
Car: a 91 rs convertible and a Iroc z convertible
Engine: 305 tbi, and 350 tpi
Just about down with my Iroc, but i am still having charging issues with the sound system on. I did the ''Big 3 upgrade", i have a yellow top Optima battery, but my volte drop dramatically with my system on. so...
WHO MAKES THE BEST DAMN HIGH OUTPUT ALTERNATOR? THANKS GUYS FOR YOUR HELP. 180AMP OR HIGHER? and also...
I KNOW A SMALL/BIGGER PULLEY MIGHT BE NEEDED, ANYONE KNOW ABOUT THIS?
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Best Damn Alternator.....Please!!!!!!!
could look at some semi truck alternators or use a pair
of cs144 type delco alternators wired in parallel-done
this before,worked good.the problem with many
aftermarket high output alternators is in order to get
the thicker winding wires on the stator the number of
winding turns is reduced-this reduces the output at
lower rpm.If you don't mind extra weight and complexity you could install two seperate batteries in
the car-one for the car,one for the stereo.
Car: 88 GTA "Cocaine"
Engine: 350 tpi
have you ran a huge wire from the back of your alt to your batt yet
maybe a dual battery set up w/isotlator
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
springhill alternators.....
I ordered a 220amp CS-130 from them and I am running the "Big 3" and just recently dual batteries (just to be safe) and I have no problem.
Lights are brighter, system sounds better, and my gauges are more accurate so in all it was worth it
Oh and you can't beat the price either since it cost me like $230 for the alt and he put a large post on it and a overdrive pulley for free.
Ragtop Man
09-12-2015 12:23 AM
