help with a aftermarket electric speedo in a 92 camaro with carb swap
Car: 92 camaro rs
Engine: 355
Transmission: t-5
Axle/Gears: 9bolt 3.27 posi rear disc
Sorry if i dont make things to clear but i can use all the help i can get. I installed a stewart warner speedo part # 114705, hooked it up straight(spliced) into the yellow wire in the speed sensor and all i get is a repeated bounce out of the speedo what am i doing wrong. all grounds and 12v sources r hooked up and checked out to be ok.
86IROC112
08-17-2015 02:00 PM
