Horn
Car: 1990 RS
Re: Horn
first off with all electrical problems check the fuses first, my guess is that your horn is grounding out somewhere. Now when your horn honks without you touching it does it do it in a repeated pattern or is it random?
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Horn
i had the same problem . mine was the contacts on the steering wheel under the horn pad . the small plastic " weld " on one of the contacts had broken . repaired with hot glue gun . good luck .
